Putting closet flange on riser
Zennifer
Northern Colorado
Hi! We need to add the closet flange. The riser is flush to the floor. It appears to be 3”. Inner diameter pipe.
We purchased a 3” push tite but are waffling on whether that’s ok with the smaller diameter. Also, when we push it in, the gasket always slides off the bottom AND it doesn’t sit flush to the floor, but instead hovers above. It can be pushed down. Is any of this acceptable?
We also purchased a steel ringed flange glue in style, but it won’t go inside the riser, even though it has an outside measurement that is the same as the inside measurement.
Help!! What flange would be the best?
Would love to figure this out. I know we should have notched the tile- we couldn’t figure out where the holes would go until the tile was in.
Have you glued anything yet? If not, you could take a rasp to the top of the pipe to remove what interferes with your preferred flange. There are also compression flanges, which do not glue in. I don't know how much straight pipe they need.
If drilling, I hope you have ceramic (hard to drill) instead of porcelain tile (very hard to drill). If porcelain, maybe see what a tile person would charge to drill that for you once you mark the right spots.
If the Pushtite flange gasket is below the straight part of the pipe, that is not going to work.
Zennifer
Northern Colorado
We have done nothing to glue anything as far as flanges. :) there doesn’t appear to be anything there interfering. (We're practicing on the cut off).
We have 3.5” of straight pipe, and the push tite is 3” long.
What flange option would be best for us with regards to clogging? (2 kids, subfloor replacement happened in part due to kids constantly clogging toilet)
The push tite's come long in case you need the length, I often wind up cutting them shorter and reposition the rubber seal.
They also make a glue in flange extension that works nice too.
If the push-tite goes in far enough, and the bowl will set over it without high centering, that would work.
Zennifer
Northern Colorado
Great- is it ok even though it’s a 3”? And can I push it down that 1/4” or so without worry?
I always use a horn but that hole is so small you might take a good look if the horn wont get crushed its good.
It looked like a perfect case for a regular closet ring just wondering why you chose the push fit vs a glue on over the pipe kind?
Zennifer
Northern Colorado
Mostly because we read on here that it was better for complete novices. :D Also the regular flange we bought (in first post) wouldn’t even think about fitting inside even with a little sanding…. I was hemming and hawing so posted above to ask, then we just went for it since it’s replaceable if we decide vs the other option? If we have any clogging issues we’ll switch. we still have diamonds left on the drill bit if we need to make new holes- my husband used to work cutting stone so he knew how to work a wet saw type thing. Took about 20 minutes to cut them all in the porcelain.
Zennifer
Northern Colorado
Argh. The flange is too high. I really think the toilet on a dry fit is rocking on the flange.
Should I pull out the pushtite and do a glue on/flatter one? Should it be an inside fit in that case? What other options?
Here is a glue on one, they have them in PVC too.
Although I think a standard closet flange for inside pipe, the short version would work too.
Zennifer
Northern Colorado
if I’m not doing the pushtite, can I use an outside fit that fits over it, and avoid narrowing the inlet? The pushtite was attractive since it wasn’t permanent, but if we are gluing…our big problems came from clogging toilet.
I don't know why your using that ring but it should work just cut a half inch off the pipe at floor then the ring will go tight to floor
