Pumptrol switching off after the 30 mins cycle of regen! Need Help
sinistral
Canada
Hi,
I got a new place with a blader tank ( 2023 ) and just bought a new Oxyfilter for the iron in the water. My well is 400 feet deep. I ran the water for 1 hour and more without loosing any water. So the well is pretty good. I have a problem since I installed the OxyFilter with Katalox Light inside. I ran a test ... So I did a backwash for 8 mins and everything good...After I had the Regen start for 30 mins....And at the end ( 0 sec ) Boom everything goes around 30 and drop to Zero. So after that I need to do a manual reboot with the pumptrol of my !"Q/$!"/$. I really need help. Don't know what to do..
I was not sure what that meant. I understand that the low-pressure cutoff tripped, but I did not understand what was going on between when things were good, and the pressure switch tripped. One thing I wonder about is if your well ran dry during the process.
If your tank is not painted, and you can see the shadow of the media through the tank when using a bright flashlight, check that he bed expansion. If KL does not get sufficient backwash rate, it can fuse together.
sinistral
Canada
The Tank is painted black.. Can't do. :( The backwash on the machine is 8 mins. After that I have a regen for 30 mins.. The water seem to go inside the tank pretty well..but at the end when it's finish.. it's going near 30 psi and the cutoff tripped. I do have a small video of 30 sec near the end of the regen.. but not working here.. it's around
  • pump.zip
sinistral
Canada
Hello guys ... My Blatter thank is a v60 hydro pro and I saw that I have 40-42 psi inside the tank if pumptrol is at zero... The max on my pumptrol I saw before closing the electricity was 50 ... So they put the pumptrol at 30/50 but it's a 40/60 everything look really bad.. do you think I just found the problem with the cutting ? Thanks
