Help pressure won’t build up to over 35
Timsmith
Tabor city North Carolina
Hi everyone I have a 1hp convertible jet pump 26 gallons per min brand new I put on there and a new 20 gallon pressure tank with the air. Then I installed both now the system won’t build up pressure over 35 psi. And I made sure to set the pressure in the tank to 28 because the on and off pressure on the pressure switch is 30-50. Now I have a house cutoff valve that I close to build up tank pressure when the system loses prime. So I let it build up for hours and it won’t go over 35 therefore the pump never cuts off. And if I run the hose for 5 mins it goes down to zero and I have to shut off the water to the house so it can build up again. What’s the problem here? Oh yea and the first reason I bought a pump for the property is because I went out there and it was a no water situation and the pump was just humming like it wasn’t turning anymore and I had to replace the start capacitor on it before so I was just ready for a new pump. So I got the model number and went shopping and got one that is basically the same specs. Any help would be greatly appreciated from me and my 3 toddlers!
In addition to not building pressure, losing prime is another problem. That can happen when the foot valve leaks, if you have a foot valve. A foot valve is a combination check valve with a screen. It can happen when you have another leak.
When you pump water, do you get air in the water? A vacuum leak, sucking air, is one thing that can limit how much pressure you can develop.
No I let it run for approximately 5 mins and burped each faucet in the house so I’m relatively sure there is no air in the line. I could be wrong. Is there another way to check for air in the line? And also I’m sure it’s a foot valve on it because it’s a deep well with only one suction pipe. So it’s set up with the jet pump doing all the work. And I checked for leaks by tightening all the bolts on the suction side.
Also thank you for the response sir, I appreciate it so much. And also I had no idea that the prime loss and low pressure was two different problems I thought they were either related or the same thing.
