war_toad
Hi all, have some interesting things going on with my pump/tank system and hoping someone can point me in the right direction.
To begin, I have a 360 foot well (mountain cabin) that pumps into a reservoir, which then pumps into the house. Both the well pump and the reservoir pump are monitored by a PumpTech system (two PumpTech boxes). In the house I have an automatic pressure switch set to 30/50 for my tank in the basement.
The house is 10 years old (purchased last year), the well pump was replaced 3 years ago and the reservoir pump replaced one month ago.
Roughly a month ago we lost all water pressure, and I had a yellow light on my PumpTech (main well) indicating an underload. When we tested the system by doing a reset, we had a blinking green light for about 10 seconds and then switched back to underload.
Long story short, we replaced the reservoir pump and the pressure switch, checked the nipple and the bladder, and filled our reservoir. Our well guy came out and said the well is still producing water and the well pump was operational (he did this by ear). The leading theory was we overtaxed our well (though we don't know how as we are quite conservative), which caused issues with the rest of the system.
Anyway, the problem: our well guy recommended that we shut down the well pump at the breaker for 24 hours and let the well recover. We did so and were happily greeted by a green light blinking for 17 minutes before going to yellow, indicating the theory might have been right.
At his recommendation, we shut the system off when we went away for the weekend. When I came back and turned on the system, this time the PumpTech (main well) started blinking green as before, but then after a few minutes all the lights turned off and the system is dark. The breaker does not trip when this happens.
I am afraid I'm learning all about this as I go, so I don't know if this is what we want to happen or if it's bad (and if so, what is wrong)
Thanks for your time!
