Hi I’m wiring my new submersible to the Pumptec 5800020116. It was setup as a 2 wire 115v. My new pump is a 240v 2 wire. I also have a trickle system and i’m having trouble finding any info on the wiring for a simple float switch with the Pumptec. There is no pressure switch involved but there is a float that tells the submersible when to turn on to fill the tank. Before one wire from the float was on L2 in the box and the other was connected to the common. The incoming hot wire as well as the black wire to my pump were connected together to the 115 terminal and the red wire was on the “Motor” terminal.
Now that I have 240 wired. I have a incoming hot going to the 240 terminal along with the black wire again from the pump. I have one wire from the float on the L2 still and the red wire on the motor terminal. Please verify if this is correct? What do I do with my other hot wire? And the second wire from the float? Connect together? Sorry the wiring diagram doesn’t help me much.
Thanks in advance.
Rob Kelman.
Sent from Mail for Windows 10
Thanks in advance.
Rob Kelman.
