I have a jet pump with an 80 gallon pressure tank, no bladder. The feedback device is all metal (at my other house it is clear plastic). It appears to have a slight leak on the feedback device since there is a lot of minerals and rust on it.
The pump doesn't seem to be acting right, at least in comparison with the similar setup at our other house; when the water is turned on, in just a few seconds the pump kicks on but only runs for about 8 seconds. This repeats over and over until the usage is stopped. I tried to drain the tank (thinking it was waterlogged) but it didn't change anything. However, I'm not sure how much of the tank I was able to drain. The flow rate seems to be fine, of course the pressure rises and falls each time the pump cycles.
