Pump Running Not Building Pressure Above 20
kbjr
Alabama
I have a deep well pump with a 3/4 hp pump. The pump will continuously run but won't build pressure past 20. I can flip the breaker off and back on and then it will build pressure to the 40 and the pressure switch will then engage and turn the pump off like it is set to do. Scratching my head on this, please help.
ThirdGenPump
MA
Shut the valve off to the house and see if anything changes.
When you shut off the breaker how long are you waiting before flipping it back on?
When you say engage do you mean the switch has a low pressure cut out switch you have to manually reset?
Is there a check valve at the pressure tank? If you shut off the pump does the pressure gauge drop?
My first suspicion would be you have a leak somewhere in the system. Closing the valve to the house eliminates anything leaking beyond the pressure tank. If there is a check valve you can not pressure test from the pressure tank(unless you remove the check) so you'd pressure test at the well.
Take some photos.
kbjr
Alabama
Take some photos.
kbjr
Alabama
I am only waiting a minute then flipping the breaker back on.
No I do not have to reset the pressure switch, I mean once the pressure reaches 40 it will stop pumping like it is supposed too.
There is not a check valve. The pressure on the gauge does not drop when I flip the breaker off. It holds at 20.
ThirdGenPump
MA
How are you confirming it's running continuously? The switch being engaged does not necessarily mean the pump is running.
Do you have an amp probe? You'll need to know if it's drawing current. It's helpful to know how many amps it's drawing and how many amps it peaks to when the pump is turned on.
Your system is set 20/40? That's rather low. Is this for household pressure?
Confirm your gauge is working. Use a tire pressure gauge on the pressure tanks schrader valve. When the system is on both should read the same.
ThirdGenPump
MA
Sorry it's late maybe I'm misunderstanding is this a submersible pump(pumps in the well) or a jetpump(pumps above ground)?
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
I am guessing it is a deep well jet with two pipes going down hole. If that is the case then I would suspect you have a clogged nozzle in the jet assembly or a small leak in the suction pipe.
