Ironjim
My well pump keeps quitting overnight. Each morning I have to play with the switches and electricity to get it going again. I cleaned off the contacts on the pressure switch and checked all the wires on it and the control box (submersible pump). When it cuts back on the psi is perfect at 40. Today I was about to change the control box when I struggled getting the electric conduit off. As I was going to google this I decided to leave the power on but to turn the well off with the cut off switch outside (its basically the same as a light switch). When i returned 5 minutes later on a whim I switched it back on and the pump came back on. Now I'm thinking the cut off switch might be bad or in need if replacement. Any thoughts?
