Pump Motor Recommendation
TVL
South Carolina
My purpose for this post is to decide if it is reasonable or wise to order a motor for my 6 year old pump head:
* The pump end was an F&W 10 GPM (model: 4F10S10301)
* At the time the Franklin motor failed, the pump end was functioning perfectly
* After removing the pump motor, the pump end APPEARS to be in excellent condition
* The impeller shaft does turn freely - no binding or other issues detected
1- Would it make sense to purchase a NEW MOTOR for this pump end, which would then give me a working spare?
2- Or, is it more practical to simply purchase an entire pump when needed?
3- If a motor replacement is recommended, what is the best brand? Franklin or any 1 HP motor?
It seems a shame to simply toss a great looking and functioning pump end, but it may not be wise to pair up a new motor with a 6 year old pump end! I'm simply trying to get some guidance.
Thanks!!!!!!!
If one has a desire, the following link documents what occurred with this 6 year old pump assembly:
https://terrylove.com/forums/index....he-bullet-deal-or-no-deal-current-draw.83416/https://terrylove.com/forums/index....he-bullet-deal-or-no-deal-current-draw.83416/
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
A 6 year old wet end should be as good as new unless you have a lot of sediment or the pump was over-sized and there was uplift.
TVL
South Carolina
That's great!
Should I get a Franklin motor OR most any brand will do?? On the other hand, is there any particular brands I should steer clear of?
TVL
South Carolina
I've come across a fairly good price on a NEW, but not in the original box Goulds/Centripro 1HP 4 wire submersible motor. The individual states the motor is about 2 years old. The motor brand is CENTRIPRO
Is Centripro the motor used by Goulds??? Or does Goulds make their own brand???
Thanks Reach!
However, this is a 4" well, so I can't put a sleeve on the pump.
PVC, steel, or uncased?
If fully cased with pvc, your pump choices should be good. Otherwise, consider a 3-inch SQ pump.
TVL
South Carolina
This is a 4" PVC cased well ……………. fully cased top to bottom.
However, can someone answer my earlier question:
TVL
South Carolina
Yes Centripro is made by Goulds, sorta. 2 year old motor is iffy. And what GPM is the pump?
1- Wet end is a Flint & Walling 10 GPM (used 6 years when old motor failed - wet end in great condition)
2- Old pump has already been replaced with a new F&W 10 GPM pump & motor
3- I was thinking of getting a replacement motor for my old wet end so that I would have a complete spare for future use.
4- You stated: 2 year old motor is iffy - please explain
TVL
South Carolina
5- Or, is it not recommended to purchase a motor (even one that was just manufactured) and let it sit until needed ………. especially when the sit time might be several years?????
Valveman
Cary Austin
Lubbock, Texas
cyclestopvalves.com
Yes. The water in the motor can leak or evaporate out. If the motor is even a tiny bit low on water when installed the top bearing and seal will fail quickly. It is not easy to replace or top off the water in a submersible motor but it can be done. I just used a motor I had stored for several years and it was quite a bit low on water. If I hadn't checked it an topped it off it would not have lasted long.
TVL
South Carolina
Thanks so very much Valveman!!!!!!
Just out of curiosity, is there a video OR online procedure/web link for checking and refilling a pump motor you can recommend or share. I would very much like to see or read about the process.
Thanks again!
