I just replaced my pump and pressure switch. No control box in system. Pressure tank is fairly new and has pressure, well has plenty of water.
When I turn breaker on the lines fill, pressure goes up to 60, switch cuts off then pressure decreases over about 2 min down to 40, then instead of pressure going back up, it rapidly drops to zero. Pump sounds like it is still running. If I turn breaker off and then back on system fills again and repeats. Does it sound like a break in the line or a problem with the switch? Something else?
