Pump losing prime
Sparky56
Michigan
I have a shallow well jet pump that loses prime overnight.
If I put a pressure gauge on the suction side of the pump before the check valve should I have the same pressure reading there as on the tank gauge?
System will hold 50 lbs psi overnight on the tank gauge.
How does one test the suction line for a leak?
Thank you
You thought the tank water heater forum was a good place for this question?
