Pump losing pressure
Eugenia Downey
I have a 1 hp deep well jet pump. I bought all new parts and pump. New ejector, foot valve, pipe fittings etc...... When we primed it the gauge went to 45 and the pump kicked off. We opened the faucets in the house and it ran good for 15 minutes and lost pressure. We checked the air pressure in the precharge tank and it is 15 psi. We have tried everything and still no pressure. The well has plenty of water. What can I do now?
WorthFlorida
Solutions
Orlando, Florida
Is the jet down in the well? Here is a cutaway of a jet pump. Either the jet is down in the well or at the motor it's the same. It is possible some debris got jamb at the nozzle. At one time I had a well suck up a small piece of metal about the size of a 22 bullet (from the original drill bit tooth done twenty years ago) and it would occasionally it get caught in the check valve and lose prime when it was turned off. Finally, one time it remained jammed in the check valve on removal and I was to remove it. Drove me nuts for days.
