2004blackwrx
Last night at midnight i had almost no water pressure. Pressure was going between 25 and 30 up and down quickly. It was late so I turned breaker off and went to bed. Woke up and turned on breaker and saw pressure go up to 60 and quickly down to 40 and so on. I have pressure set to 50 70. at this point i start to think i need a new water tank. I drain system and tank pressure is 48 on the air side. Now im not sure whats wrong. So i turn breaker back on to troubleshoot more. Now pressure goes up to 60 and hovers around there. i hear flow starting and stopping. I look at pressure switch contacts and see they are closed but flow is stopping and starting and pressure is around 60. I now call my dad for advice. while on phone I notice system working like it should. I then decide even its working now problem will come back so i decide to replace pressure switch. I install new pressure switch and the problem persists. as further note control box and pump were replaced last month when my pump died.
