Hi - I recently had a 1.5 horse submersible well installed to use for a sprinkler system. Because of the variety and location of the stuff I need to water, I find I do not have enough flow in some of my zones to keep the pump from short cycling (i.e. it cuts on at 40 psi and only takes 10 seconds to reach the 60 psi cut-off)
If I understand the programming on the Hunter SRC Plus controller I have, I can not program 2 zones (valves) to come on at the same time. Is it ok to connect two valves to the same zone on the controller? Or is there another way to do this?
Thanks, Floyd
Thanks, Floyd
