“Properly grounded” - GFCI “no equipment ground”?
CTho
Colorado
Hi, I’d like to switch to a tankless water heater to recover a closet in my (small, limited-storage, old) house, and I’ll need to have an electrical outlet added. Unfortunately the existing house wiring has no grounds, so GFCI receptacles provide 3-prong outlets where necessary. Would that count as “properly grounded” for installing a tankless water heater, or do we need to have a whole new circuit added with a real ground?
Bcarlson78248
Alexandria, VA
Have you already picked out a tankless hot water heater, and it is gas or electric?
Is the receptacle you need just to provide electricity for the controls for the tankless HWH?
Bruce
Stuff
Pennsylvania
There is NO "tankless water heater" that "plugs in" that will give you anywhere the quantity of hot water you would need for even a single faucet.
hj - Assume it is a natural gas tankless that needs 120v. I doubt a true ground is needed but you never know.
CTho
Colorado
Sorry, to clarify, it would be a gas tankless (probably a Rinnai RU160iN or RU180iN), so the electricity is just for relatively low-power things (electronics, flame starter, blower...).
I looked through a few Rinnai, Noritz, and Vesta installation manuals and they say things like “A standard 3-prong 120VAC 60Hz properly grounded wall outlet” or “electrically grounded in accordance with local codes”.
