I see that there are lots of questions on the board about low pressure. I am wondering what is the proper line pressure High/low for good pressure in the house.
Some Background:
House built in 2000, 4 full baths plus a 1/2 bath. Separate HW tank for the master bath. 220' well. WellXtrol accum. tank.
I checked the bladder in the tank the other day and it was reading about 48PSI. The tank instructions say to make it about 3PSI lower than the cutoff. I seem to remember that adjusting the screws is how the high/low is set. What should be the "normal" high pressure be? What's the best way to cycle the system to check the high/low kickout. Use someone in the house to run the water and tell them when to stop?
Pressure is just lame in our master shower. The other's aren't too bad. I've tried changing out the whole cartridge insert in the shower but it hasn't helped.
Some Background:
