Jkeyler
- Messages
- 11
- Reaction score
- 0
- Points
- 0
I have a one piece toilet that I purchased at Sears about 1975 (probably a Rumble brand) and I have just intalled a new Ball cock Assy and Tilt valve (which I purchased through Sears Parts Center). I replaced the previous items since the water was running contiunously as the tilt valve apparently was worn, etc. After I installed the new assy's, the tilt valve is allowing more leakage that I had with the previous one. I have tried additional weight washers, also checked to see that the lift strap was not too tight, and so on. I cannot get this leakage to stop. I would like to know who manufactures these replacement assy's and can I buy then anywhere other than Sears. Also, most improtant, does anyone have any ideas as to what I can try to stop the continuous leakage and make the tilt valve seal so it does not leak.
Any help would be greatly appreciated as I've got to get this solved someway. Water is getting costly.
Indy Jim
Indy Jim
