We recently did a complete gut and rebuild on back-to-back second floor bathrooms. The finished tile floors ended up being higher than was anticipated when the rough plumbing was done. This leads to a problem in one of the baths. See attached picture. The top edge of the 3 inch sanitary tee hub that the toilet flange will connect to is approximately 1 inch below the top of the finished floor.
1. The toilet flange tailpiece that would fit into the hub is not long enough - it only goes about halfway into the hub, so I can't even get a friction fit when test-fitting it.
2. Alternatively, there is not enough room to allow using of a small section of 3 inch pipe into the hub and then using a flange that would glue over the pipe - the flange would sit about 1.25 inches above the floor.
3. My only thought is to glue an even shorter piece of 3 inch pipe into the hub, (so it just is even with the hub lip) and use a flange such as Sioux Chief 888-PM that has a 4inch long tailpiece that fits inside a 3 inch pipe and trim the tailpiece so it doesn't bottom-out in the sanitary tee. However, I don't like reducing the pathway down to this smaller diameter and am not sure it is even legal.
Any thoughts or suggestions?
