Mad Plumber
Mad Skills
Please advise on preventing sump pump discharge lines from freezing and can you tell me if you can connect the discharge from sump pump to the downspout output that connects to the storm drains. Please give detailed instructions on how to bury the extended dishcharge pipe from the sump pump pipe.What size to use , What pipe to use. Is there an insulated pipe.Is it adviseable. to tie in to downspout lines. What is an Iceguard. I read about installing a tee. How does that work.How deep do we go and what materials are needed. Thank-you
Linda
Linda
