Bushing or barb fitting reducer is fine. I would use a rigid nipple through the well seal. Means you probably need a coupling on the barb fitting, 6' nipple through the well seal, and a tee to set on the well seal and feed the house.
Sounds fine to me.I have almost everything I need for the install, I am just a little confused about the wiring. I have a 20 amp wire(yellow wire) heading towards the area, it just ends close to the location of the conduit that goes to the well pump. According to the electrical requirements for the pump it says use a 20 amp breaker. I assume since the pump is 230 volts I use a double pole 20 amp breaker. So to keep within code can the current wire safely be used for a 20 amp double pole breaker? I know I can use a neutral as a load wire I would just use electrical tape to mark it as a load. I'm probably just overthinking it again. I believe I ran across a post on here that said it would be fine.
If you are using a well seal, then yes. The weight would be borne by the fitting on top of the well seal.Other question is would it be better to use a bushing to reduce the fitting size for the barbed fitting or could I just use a reducing barbed fitting to go from 1-1/4" to 1"? I assume it would be just as strong either way and the less fittings I have down the well the better as far as I am concerned. I'm a bit lost as to how to end the poly pipe just before it pops up through the cap. I am assuming again that I use a barbed fitting then use a coupling so I can attach a nipple to it and pop it through the hold in the cap and to a 90.
Even if you are in the part of Oregon that does not freeze, a pitless adapter is better IMO. Not everybody agrees. The pitless would usually have a female NPT thread, and the barb would screw into that.Or is there some other way it would go through the cap that would be more secure? Seems most pumps go to a pitless adapter which I dont believe I have down the well. If there is one there I have no idea where it would feed to.
People add pitless adapters fairly easily usually. There are different kinds. What is the ID or OD and material for your casing that sticks out of the ground? That will play a part in selecting the pitless adapter.
Post a photo of what you can see.I have never had the well cap off so I dont know what it looks like down the hole.
How long? Five minutes?It kicks on after the toilet is flushed now and it takes a lot longer for the pump to get the system back up to pressure to turn off but otherwise its been ok.
That probably indicates that the pump is degrading. You should probably adjust the pressure switch down by about 5 psi for cut-in and cut out. You would also adjust the air precharge if you have such a pressure tank, which I think you do not.I'd say at least, sometimes seems like 10 minutes. Its roughly twice as long as it used to take a few years ago. I did check the pressure tank to make sure it was set properly. It was waterlogged some as usual but I corrected that. Bladder tank would be a lot easier to deal with. The one I have now is just a holding tank being used as a pressure tank. 5 minutes seems about normal for that pump. One time I believe it took 20 minutes.
What kind of tape or pipe wrap is wrapped around that flow inducer?Then you have nothing to worry about. I don't know how many times I have said it but back pressure is good for the pump/motor. Back pressure makes the motor draw lower amps, run cooler, and last longer. As long as your pipe is good for the 147 PSI, which is nothing for most pipe, you are not going to hurt anything and it will actually make everything last longer.
As for the flow inducer, all you need is a ten dollar piece of 4" drain pipe. Like this.
