zorro
I know there are similar posts to this, but could not find any posts for a completely empty property which appears to be consuming more power than my current property, where 4 adults reside!!
I just purchased a new property (new to me - 55 years old) - currently it is empty/unfurnished
The only item I can see that is currently plugged in and running is the Refrigerator - the house is totally empty
I have oil heating (forced air), which is on just now to prevent any freezing
I have a well in the yard
There are no outside lights/secruity lights, etc running
I am not sure if hot water is oil or electric and am trying to find that out
I have no gas in the property - only oil/electric
At present, I appear to be using 21kwh per day (my use for 26 days was 546kwh)
In my current house, there are 4 adults with all the usual appliances - wahser, dryer, 3 x TV's, 4 x laptops, forced air, etc, etc, my use for the month was 525kwh - so for the house that is totally empty, I appear to be using more power each month than my currently home
Over the weekend, I am going to try flipping the circuit breakers, etc one by one to try and idenify what is causing the use, but anyone have anything else I should try to see why this is being used?
I spoke with the power company and they have suggested the following;
I'll summarize below what our next steps can be.
- take a photo of the meter when you arrive this weekend and send to me
- note how fast the disc is spinning (if spinning pretty fast, time how many seconds it takes from the black mark to make a complete revolution), write it down
- if possible, and your home inspection found nothing unsafe w/the breakers, locate the well pump breaker and leave that ON. Turn off all others and look at the meter. The disc in the meter should be stopped (unless you just ran water). If it's moving slowly, wait a few minutes. The disc should come to a complete stop in less than 4 minutes. If the disc continues to creep along, there could be an issue w/the well pump
- if no issue w/the well pump, go ahead and turn one breaker on at a time and observe the meter after each single breaker is turned on to see which circuit causes the disc to turn
- find out if the water heater is electric or oil
At anytime you notice the disc spinning fast, time how many seconds it takes for one revolution. Below is the formula to determine how many kilowatts are running.
# of revolutions per minute x 7.2 x .06 = kilowatts
Lets say you time the meter at 10 seconds for one revolution. We would then say it take 6 revolutions per minute. Using the formula above that would be a load of 2.6 kW or a total of 2600 watts running on the meter at that given time.
Any other suggestions?
Thanks
Paul
Thanks
Paul
