Possible to install TOTO Ultramax 1 or 2 in a 10" Rough In?
If you could get a Toto that uses the Unifit adapter, and you will also need to by a 10 inch Unifit. The newest Aqua models use Unifit too.
The Drake has 10 inch versions too. Those are 2-piece and no Unifit. Those will cost less than the Unifit units, but if you want single piece, the Toto offerings would all use Unifit I think.
https://www.totousa.com/products/toilets#filters=rough-in:10150000000026367712 shows choices. The prices there are list prices, so you will usually be able to do substantially cheaper locally if you are in a metro area. Toilets don't ship to houses very well. The local supply houses usually have quantities delivered on pallets, and they survive much better that way..
https://terrylove.com/wc/unifit.htm
