Plumbing a Freestanding Tub
Ewhite111
Arizona
Hello! I just removed a tub and looking to replace it with a freestanding tub (thank you wife).
Please help with the plumbing on this. Correct me if I’m wrong:
From the tub drain, I would use a OSB ITD35 to a 1 1/2 ptrap and trap arm and then use 2 45 degree pieces to connect to the existing drain. I’ll cut off the old ptrap.
Where do I make the change from 1 1/2 in to 2 in pipe?
Thanks for the help!
Picture is attached.
Tuttles Revenge
#1 Do you have the tub you are installing already? use that as your template to locate your drain coming up out of the floor. Know exactly which waste and overflow you will need first so you can stub up with the correct size. Installing on a slab limits your options. Tubs only need a 1.5" trap and trap arm. 2" after the vent.
Is this tub being installed in an alcove where an alcove was installed? Will there be enough room to do that? What sort of filler will you be using, Wall or floor mounted? Lots to think about in where and how the water is located.
Tuttles Revenge
Here is an install that a friend that used to work for me did in their home in Vegas this summer. I recommend leaving at least 1" between your tub and all finished walls so you dont create pinch points for fingers.
Those things look a lot harder to clean than conventional tubs, but that gap you recommend at least makes it possible.
Maybe there are cleaning tools designed for the purpose.
How about using rope like giant dental floss?
Tuttles Revenge
Nah... just name the Dust Bunnys that grown and live behind the tub
WorthFlorida
Solutions
Orlando, Florida
Hello! I just removed a tub and looking to replace it with a freestanding tub (thank you wife)..........
You're not the first one where the wife watches too much HGTV, just like mine. They look great on TV but not all practical, difficult to install, heavy and just wait until they go out of style. Remember when all dining room walls were painted red? Three coats of KILZ and two coats of paint needed to cover it with a different color. :D
Ewhite111
Arizona
Yes, I have the tub and it’s a 1 1/2 in screw on connection to the drain. The overflow is part of the tub and leads to the same drain underneath.
Would the 2 45’s work better than 1 90 to make that turn to the main drain after the trap arm?
We put the filler in the wall and that’s all set. We left about 4 inches on each side of the tub.
so getting close, just wasn’t sure of the drain.
