Please review my DWV layout
bjohns
Arkansas
First I want to say thanks for all the helpful information I have found on this site in the past few weeks. I am a Carpenter by trade, and we are building a new house, and I plan on doing the plumbing. I have moved a little plumbing before in a bathroom remodel, but this will be my first under a slab, so I would like some opinions on my layout. This is for the Bathroom, house located in Central Arkansas. I just have the pipe stuck together in order to take a picture and have extra length on each piece for final fitment. Vents will tie together in the attic and exit as a 3". Also, is there a minimum height that the risers need to be on the commode and shower drain? I plan on using a 4"x3" closet bend for the commode, I just havent gotten it yet.
Tom Sawyer
Maine
Yea, that's fine. If that's 3" that the lav dumps into it can be 2" or if you're IPC, 1-1/2" and it still wet vents the toilet. The shower vent can be 1-1/2" also.
quote; If that's 3" that the lav dumps into it can be 2" or if you're IPC, 1-1/2"
I am not sure about the IPC "anything goes" code, but under the UPC he would need vents through the roof that equal the AREA of the incoming sewer so it that and the tub vents are the only ones he WOULD need a 3" vent because there is no combination of two smaller vents that would equal the area of a 3" main line.
Tom Sawyer
Maine
IPC requires one vent through the roof that is 1/2 the diameter of the building main so 3" main = 1-1/2" vent although it needs to be increased to 3" at the roof penetration.
bjohns
Arkansas
I plan on leaving the 3" vent there and would tie the 2" or 1.5" (if sufficent) from the bath to it in the attic. I don't think I can get "too much" vent.
bjohns
Arkansas
What are you going to do for a clean-out?
I had considered running 3" pipe on straight, where is reduces down to 2" for the shower about another 8 feet to outside the house, that way I could rod the main line. However, I'm not sure if that is acceptable or correct.
My next option would be to put a Wye pointing upward between the Wye for the Commode branch and the 3" to 2" reducer, which would come above the floor inside a closet, mostly covered by a perpendicular wall where I could make a little access, but i'm not entirely sure.
Any suggestions?
Tom Sawyer
Maine
By code ou need one at the base of each stack so put a dandy on both the lav drain and shower vent
bjohns
Arkansas
actual progress
I have actually begun working on this. Does it look ok overall? Also, I bought 3/4" type K copper, and the guy at the supply house recommending sleeving it in 1" poly tubing, which I like, because the poly is tuff stuff. He said to put the copper in the poly and then bend it. Any thought or tips on this?
pic 1, is facing upstream toward the bathroom (shower drain not done yet)
pic 2 is 180 degrees the opposite direction toward the other side of my house
pic 3 is where my branch will connect for the kitchen sink
pic 4 is where my branch will connect for the washing machine
pic 5 is where it exits the house
Tom Sawyer
Maine
It looks good but don't forget to x brave and properly bed and backfill or sags will develop when the floor is poured.
mahuska
iowa
URC says waste stack vent size must be equal to waste stack [3109.3]
Tom Sawyer
Maine
What the hell is the URC. Oh yea universal residential code. Anyhow, I believe Arkansas is IPC but at any rate we ain't talking about waste stack venting here.
