Brian94
Lubricating the thread helps. Stainless steel threads have a nasty habit of galling if dry.
Thank you I will retry my connection and update.
Beautiful job! Just loosen all the way on the small adjustment in the pressure switch to get the minimum delta between on and off. If that Square D switch doesn't adjust like it should just let me know.
I did loosen it the whole way out to where the spring flopped around, which should have given it the minimum as stated. Then again I should have just bought a new pressure switch from you, since I'm reusing my old one. It's a home desperate everbilt switch. It did have some rust sediment in it that I tried to clean out. I'm assuming there could still be a little more stuck in there creating issues with the diaphragm. Probably better off just buying new switch?
