Tuttles Revenge
- Messages
- 4,200
- Reaction score
- 1,455
- Points
- 113
Leaking expansion joints are installer error near every time. Or a messed up fitting, but that still falls back on the installer to inspect to make sure there are no nicks in the fittings sealing surfaces.
Correct installation is to ensure your cuts are square, the expansion ring with stop is set correctly on the tube so that the tube is inset from the end of the ring slightly and that is what the stop end of the expansion ring does. Expand and rotate the expansion fingers with every expansion of the tool. (this is likely where your leak occurred) Hold the expansion head open on your last expansion. Insert fitting into expanded tubing and hold til the tube shrinks back down.
If the fingers expand in the same point repeatedly the tube stretches laterally and unevenly in the area that is supposed to be uniformly stretched when it comes into contact with the perfectly round sealing surface of the fitting.
We always work backwards to the point of connection when we're doing water installations. Install all your tubing first then connect to the source so you only have a few minutes of downtime. But this does rely on having 100% confidence that all of your work is going to hold. A simple air test prior can confirm this too.
Sometimes in the olden days of Wirsbo installations, we would be working in cold environments and pressurize a system too soon. Some of the fittings would drip. But they would be sealed up by morning. The contraction just took longer.
In this case, if you're curious enough to find out what happened to that particular joint, I would cut it out an inspect the tube surface to see if it has lines that correspond with improper rotation.
