Panasonic FV-10VEC1 ERV
Llavey
Minnesota
Has anybody installed the model listed above or the FV-10VE1 warmer climate version? This looks like a very nice little unit that would serve my needs perfectly but, I do have one question for anyone who has installed one.
Has anyone installed the unit on a wall with the power cord facing down vs up, as shown in the installation guide? This would flip the direction of the EA/OA and RA/SA ports and put them inline with the direction I need to run my ductwork. Preferably, I would be able to move the door hinges so the door would still swing up. The manual does not cover this and without physically seeing a unit it is hard to determine if it is possible.
Thanks in advance for your comments.
Llavey
Minnesota
Ok... Looks like nobody has installed one on this forum. Thanks anyway.
WorthFlorida
Solutions
Orlando, Florida
Never seen one and I think I understand your issue. Reading into the manual in the setup section, reversing or flipping the unit for lack of another term, the inside air and outside air temps are read to control the airflow. Therefore, there must be processor in to read temperatures and then change speed of fans, baffles, etc. Then the unit would not function as designed. There might be baffles inside the unit tobe sure that the air flow cannot be reversed. Though what you want to do does not change airflow direction. If this was a 100% mechanical and no variable for temperature changes it probably would work. It does look like a nice unit.
Llavey
Minnesota
Thanks for the rely. All I am looking to do is rotate the unit 180 degrees from the installation manuals instructions. Not change the flow of any ports. I'm going to buy one and se what can be done. The worst thing thing would be its not possible and my installation is not as clean as desired.
