B.E. DuBose
- Messages
- 2
- Reaction score
- 0
- Points
- 0
I have a well in my yard. It is very old and has been out of service for quite sometime. I wanted to get it working again. It is a 3" casing with a packer jet assembly. I loosend the flange bolts from the casing and tried to pull it up by hand and it would not budge. I hooked a chain to it and tried to pull it up with the rear bucket on a small backhoe without success. Be advised at this point I was not even sure what I was dealing with. So I started turning the 1.5" drop pipe counter clockwise. I pulled up approx. 42' of drop pipe only to find there was a coupling on the end. I realized then what I had done, I had left the packer jet down in the well. I think I can drop the pipe back in the well and screw it back on the packer jet. Any suggestions on how I can get the jet unstuck from the well casing? Do they make anything you can pour in the well to loosen up the leather seal? If so what is it? Could someone please talk me through this. Thank you so much!! Brian
