Offset toilet flange for 4” cast iron pipe?
Baltik
SF
I’m in the middle of a bathroom remodel and am facing a small dilemma. The existing 4” ID cast iron connector has a busted flange and is 11” from the wall vs the 12” I need for my Woodbridge toilet. I’ve found a few offset adapters but they would raise the toilet about 2” higher which wouldn’t work, any ideas?
basically I need something like this with a 1” offset
https://www.homedepot.com/p/Oatey-Twist-N-Set-4-in-Cast-Iron-Toilet-Flange-436532/100171634
this is what I’m finding which would raise the flange height
https://m.ferguson.com/product/prof...-standard-closet-flange-pfcfcoppk/_/R-7000231
Sylvan
Still learning
New York
Sylvan
Still learning
New York
Either one of these should work THEY do make a CI IC offset CI floor flange
You have a picture of a Code Blue C40640
https://www.homedepot.com/p/JONES-STEPHENS-4-in-x-2-in-No-Caulk-Code-Blue-Cast-Iron-Water-Closet-Flange-with-1-in-Offset-C40640/313740731
https://www.supplyhouse.com/Jones-S...Closet-Flange-w-5-16-Bolt-Slots-4-Offset-Blue
I don't know how high that puts floor level above the top of the cast iron pipe, but I am confident it is not 2 inches. They should specify that IMO.
I think you are implying that your cast iron pipe comes up to the level of the finished floor, and you don't want to grind the pipe lower.
wwhitney
Berkeley, CA
How about a picture of the existing conditions you are dealing with? And you're looking for an option that doesn't require cutting/removing the floor around the outside of the pipe?
Cheers, Wayne
Baltik
SF
Right - my pipe is slightly above the floor level, it’s also an elbow so I don’t think I can cut it much, photos for clarity
That does not look like just a pipe, but maybe a pipe with something outside of it. Or maybe it is a cast iron hub with stuff inside of it. You can use a magnet to distinguish iron from non-magnetic materials.
Are you going to add a finished floor such as tiles or hardwood or laminate? Consider that thickness in your plans.
If you lay a straight edge, such as a level, across that round part, how far down is the pipe from the straight edge? How far above or below the straight edge will the finished floor be?
Click Inbox, above.
Baltik
SF
Appreciate the advice, the pipe i have appears to be lead and is part of original construction from 1967 it's 4"ID 5"OD and start to curve almost immediately. I have some flexibility in terms of height but can't do a full 2" rise. That means that the adapter should be an inside fit adapter that will go inside the 4" pipe and be offset by an inch?
Sylvan
Still learning
New York
EASY Fix, Remove the old CI and lead and install a caulked CI Floor flange
Baltik
SF
Hi Sylvan - are you referring to removing the old flange? or the actual CI elbow? I do not have access to the piping aside from the top so replacement options are limited. Is there an offset caulked CI floor flange?
Sylvan
Still learning
New York
Remove the lead caulked piece and old flange part DO NOT damage the cast iron pipe
Buy a caulked CI Flange and pack oakum to allow for a depth of 1" lead NOT lead wool but molten lead on DRY oakum
Look carefully at the flange choices
If you have XHCI you have to use a caulked flange and one with an offset .
These work great on cast iron and galvanized steel when you do not have access below
Leave the ell alone
Lead does not attract a magnet. So you might test various areas to see if there are pieces that attract the magnet.
Baltik
SF
ok, feels like I'm finally getting my head around this with everyone's help, i confirmed using a magnet that i have lead on the outside. So I guess that leaves the question of whether I have XHCI or regular 4". Does anyone know the OD of these standards?
Mr tee
Montana
The old lead should not be hard to remove with a chisel, it is soft. Use a caulk ring with oakum and you can melt the old lead and reuse it. If the pipe is a bit above the floor, that is where you want it so that it is near the top of the ring which should sit on the finished floor.
