Noritz model NRC1111DC/SV Error code 90
Discussion in 'Tankless Water Heater Forum' started by Michael Tourigian, Mar 4, 2020.
  1. Michael Tourigian
    Michael Tourigian New Member
    Mar 4, 2020
    Brigantine, NJ 08203
    I have tried everything that Noritz teck has told me to do. Descaled unit, cleaned fan motor, had larger gas meter installed, set dip switches to 2 & 3. I am using 3" PVC pipe and the exhaust pipe in around 12 feet long with two elbows plus a rain cap. I may have a gas pressure issue and may need to get a manometer to check gas pressure at the unit. Before I go through that should I have the gas company come and check out the gas pressure coming into my unit? This has been an ongoing problem for over a year I keep resetting the unit and it will run ok for about 2 weeks then trigger a 90 code not any fun when you are taking a shower. I recently called Noritz again and was told that I could try to change the dip switches to 7 & 3 instead of 2 & 3 which it currently is. Not hopeful that will correct my problem but will try. Any help full comments would be appreciated.
  2. plumber69
    plumber69 In the Trades
    Jun 20, 2014
    Prince Rupert, British Columbia
    Ran into something like this, probably is gas pressure, usually a simple adjustment. Running multiple gas appliances at same time along with it can cause it
Similar Threads: Noritz model
Tankless Water Heater Forum Noritz Model N-0751M-OD Scale Removal Success Story Jan 22, 2012
Tankless Water Heater Forum Noritz NR98-SV ideas requested Jul 17, 2018
Tankless Water Heater Forum Minimum flow needed to light has increased, Noritz NRC1111-DVNG Jun 8, 2018
Tankless Water Heater Forum Any experience with the Noritz EZ111DVNG (GQ-C3259WX-FF US NG)? Dec 24, 2017
Tankless Water Heater Forum Noritz Tankless Battery Backup Oct 8, 2017
