adi
I bought noble ts membrane to water proof my steam shower. I was having trouble installing as it seemed that the modified thinset wasn't really sticking to the back side of the noble ts. I ended up back buttering the ts and getting it on the wall and the shower floor. When I did a flood test one of the corners leaked. I've fixed that corner but do feel some air pockets. I only have a few air pockets mostly on the floor, but a few small ones on the wall. You have to really poke around to find them, so they are not very pronounced. How big of a problem is this? Once I put the other layers of ts overlapping on the walls, and the tile/mortar on tile on top of the floor will that resolve the issue?
So I was debating...should I rip everything out and go with the kerdi board system and preformed kerdi floor? I originally went with noble because i read that noble ts has a higher perm rate so it is better for a steam application. Is kerdi board ok for steam as well? I would hate to start from scratch but want to make sure everything i have done so far with the noble ts is common? thanks.
