New Fleck 5600SXT 64k, please check my settings.
Maher871
Denville NJ
Finally had a softener installed. Just looking for some help to verify the settings on the 5600sxt.
Fleck 5600sxt, 12"x52", paddle wheel meter
BLFC : 0.50 gpm
DLFC 3.5 gpm
Blue Injector
cubic ft resin : 2.0 , 10%
Raw hardness : 20.0 ; city well water. No Iron
Estimated gal/day - 5 people ; 288.0 gpd ; 57 gal per person average
Can someone please double check the settings they left me with so I can confirm they are efficient.
Thanks Again
-DF = GAL.
- RF = DF1B.
- CT = FD.
- C = 40 X 1000.
- NT= 1
- H = 20
- RS = SF.
- SF = 20
- DO = OFF.
- RT = 02:00
- BW = 6
- BD = 60
- RR = 8
- BF = 8
- FM = P0.7
System info (not programmed)
salt lb/cuft = 6.75 ; A choice ( efficiency vs capacity)
BLFC = 0.5 ; Brine Refill rate GPM
cubic ft resin = 2 ; ft3 resin = (nominal grains)/32,000
Compensated hardness = 22 ; including any compensation
People = 5 ; gallons affects reserve calc
Estimated gal/day = 300 ; 60 gal per person typical calc
Estimated days/regen = 6.68 ; Computed days including reserve
Fleck 5600SXT Settings:
DF = Gal ; Units
VT = dF1b ; Downflw/, Single Backwash, black cam
CT = Fd ; Meter Delayed regen trigger
NT = 1 ; Number of tanks
C = 46 ; capacity in 1000 grains
H = 22 ; Hardness-- compensate if needed
RS = rc ; rc says use gallons vs percent
RC = 300 ; Reserve capacity gallons
DO = 30 ; Day Override (28 if no iron)
RT = 2:00 ; Regen time (default 2 AM)
BW = 5 ; Backwash (minutes)
Bd = 60 ; Brine draw minutes
RR = 5 ; Rapid Rinse minutes
BF = 10 ; Brine fill minutes
FM = P0.7 ; https://terrylove.com/forums/index.php?attachments/img_fleck5600sxt_flow-png.31592/
FM pix: http://terrylove.com/forums/index.php?attachments/img_fleck5600sxt_flow-png.31592/
Revised based on number from https://terrylove.com/forums/index.php?threads/help-for-programming-fleck-5810.82673/#post-595983
The less salt per cubic ft, the more salt efficient, but more hardness breakthrough.
BLFC 0.5
cubic ft resin 2
Alternative capacity (C) and brine fill (BF) pairs. Round C down.
lb/cuft C= BF=
6.0 42.0 8
6.8 44.5 9
7.5 46.6 10
8.3 48.6 11
