Fleck 7000 SXT Settings
rgvomar
Deep South Texas
I was having issues with low water pressure and based on what I read here I came to the conclusion that the resin needed to be changed. I just put new 10% crosslink resin in my tank. I now need some suggestions on what settings I should use. I have 2.0 capacity tank 64,000 grain. The injector color is red.
I'm on city water and the hardness is 29
These are my current settings:
Fleck 7000SXT Settings:
DF = Gal ; Units
VT = dF2b
CT = Fd
C = 48.0
H = 30
RS = rc
DO = 28
RT = 2:00
B1 = 8
Bd = 60
B2 = 5
RR = 6
BF = 21
FM = t1.2
Any suggestions on what settings I should have would be greatly appreciated. I'm more concerned about having soft water regardless of how much salt I need to use.
Check the BLFC... If that is 0.25 gpm, I would go with the following... very much similar to what you are running now, except that I upped the BD to 100 because you are using the #0 Injector - Red
System info (not programmed)
salt lb/cuft​
8​
A choice ( efficiency vs capacity)​
BLFC​
0.25​
Brine Refill rate GPM​
cubic ft resin​
2.0​
Same as (nominal grains/32,000)​
Raw hardness​
29.0​
including iron etc​
Estimated gal/day​
120.0​
60 gal per person typical calc​
Estimated days each regen​
11.5​
presuming days each use reserve capacity​
DF​
Gal​
Units​
VT​
dF2b​
Downflw/Upflw, Double Backwash​
CT​
Fd​
Meter Delayed regen trigger​
C​
48.0​
capacity in 1000 grains​
H​
35​
Hardness grains after compensation​
RS​
cr​
Cr = base reserve on recent experience​
CR​
0​
0 is default (leave it)​
DO​
28​
Day Override (typ 28 if no iron/Mn)​
RT​
2:00​
Regen time (default 2 AM)​
B1​
8​
Backwash 1 (minutes)​
Bd​
100
Brine draw minutes​
B2​
5​
Backwash 2 (minutes)​
RR​
6​
Rapid Rinse minutes​
BF​
21​
Brine fill minutes​
FM​
t1.2 (usual)​
t1.2 is default flow meter​
