Fleck 5600sxt programming help
akirkland
San Antonio TX
Hi, I just purchased a Fleck 5600SXT with a 64,000 grain capacity tank.
The notes on the side of the valve state: Injector - 2, Drain Flow - 3.5GPM
The paperwork states it comes with 10% crosslink resin
We have a family of 6 with the possibility of guests in an apartment above our garage, so maybe 6-8 at any given time.
Hardness tested at a 12.
Settings I have now are...
DF - GAL
VT - dF1b
CT - Fd
NT - 1
C - 45
H - 12
RS - SF
SF - 10
DO - 14
RT - 2:00
BW - 10
BD - 60
RR - 10
BF - 12
FM - P0.7
System info (not programmed)
salt lb/cuft​
7.5​
A choice ( efficiency vs capacity)​
BLFC​
0.5​
Brine Refill rate GPM​
cubic ft resin​
2​
ft3 resin = (nominal grains)/32,000​
Compensated hardness​
13​
including any compensation​
People​
6​
gallons affects reserve calc​
Estimated gal/day​
360​
60 gal per person typical calc​
Estimated days/regen​
9.85​
Computed days including reserve​
Fleck 5600SXT Settings:
DF​
Gal​
Units​
VT​
dF1b​
Downflw/, Single Backwash, black cam​
CT​
Fd​
Meter Delayed regen trigger​
NT​
1​
Number of tanks​
C​
46​
capacity in 1000 grains​
H​
13​
Hardness-- compensate if needed​
RS​
rc​
rc says use gallons vs percent​
RC​
360​
Reserve capacity gallons​
DO​
30​
Day Override (28 to 30 if no iron)​
RT​
2:00​
Regen time (default 2 AM)​
BW​
5​
Backwash (minutes)​
Bd​
60​
Brine draw minutes​
RR​
5​
Rapid Rinse minutes​
BF​
10​
Brine fill minutes​
FM​
____0.7​
salt lb/cuft​
7.5​
BLFC​
0.5​
cubic ft resin​
2​
13​
People​
6​
Estimated gal/day​
360​
9.85​
DF​
Gal​
Units​
VT​
dF1b​
CT​
Fd​
NT​
1​
Number of tanks​
C​
46​
H​
13​
RS​
rc​
RC​
360​
DO​
30​
RT​
2:00​
BW​
5​
Backwash (minutes)​
Bd​
60​
Brine draw minutes​
RR​
5​
BF​
10​
Brine fill minutes​
FM​
____0.7​
Thank you!
For the BLFC, is that the number I posted that is on the side of the pump? 3.5? If so, would that change anything?
Not sure if this makes a difference, but the distributed water in my area has iron levels of 0.007 ppm...
Also, if I wanted to lower any sliminess, what would be the best way to tweak?
No. A "64000" grain tank would normally be 12x52. A 12 inch diameter tank normally uses a 3.5 gpm backwash and fast rinse.
The iron does not reach you.
Reduce BF to decrease the amount of salt used per regen. C would normally also reduce a bit, but let's leave that for now. Also, the resin arrives pre-regenerated, so your settings only come into play later.
