Jeff_Bathroom
Thanks very much Terry for your help; I really appreciate it.
I have a few more questions if you all have time. I've attached a photo of the main drain on the far left and the existing 2" drain connecting to it. This is the drain that currently services the washer and the utility sink. I have to run the 3" drain for the toilet, so I'm considering replacing this 2" with the 3" and connecting the existing vent system to this new 3" drain.
1. Most pictures I see of toilet drains show an immediate closet bend under the flange. Is there anything wrong with having the drain go straight to the
ground about 3 or 4 feet before leveling out to near horizontal?
2. How far from the fixture (toilet in this case) can the split-off for the vent be? Reason I'm asking is that if the vent "Y" connection to the vertical drain were closer to the ground, I may be able to run the vent at 45 degrees or so up to the adjacent wall where the vent is rather than a partially horizontal run as discussed above. I have read that the vent should be close to the fixture but I don't know what the drawbacks are of having it further away.
3. I know there's supposed to be at least 15" from the toilet center to the nearest wall or fixture. What if the toilet were in the corner facing diagonally outward? The bowl would be in spec, but not the back of the toilet since it's basically right next to each wall. Is this still considered in code since the sitting portion of the toilet is in spec?
Thanks again for your help...
