New attic drain into existing
TheZster
Fort Collins, Colorado
I have a 4" stack with a bathroom on the first floor draining into it. I want to add a bathroom in what used to be the attic - directly above the existing first floor bathroom.
Can I tie in a new 3" line from the new bathroom into the existing stack "above" the first floor toilet without a separate vent for the first floor toilet? Or do I need to bust out concrete and connect the new system "below" the existing first floor bath? The new addition will have it's own vent system...
If possible/necessary - I have plenty of room to add a vent line right above the existing toilet - between the existing toilet and the planned addition (4X4X3 Y)....
Jimbo
San Diego, CA
By UPC, and probably other codes, you cannot turn that VENT stack from the first floor toilet into a WET VENT by draining waste into it. What you can do is use that 4" as your WASTE STACK, draining the new second floor toilet into it, and tie a separate vent fromt the first floor, and tie it back into the 4", 42" above the second floor level. No need for a new roof penetration.
TheZster
That is totally do-able. If I read you correctly - I can add a 2" vent line above the existing toilet (is 2" big enough? - I'm running out of room) - and tie it back into the main stack just below the roofline (assuming the 42" rule - if I don't have 42" - I can run the first floor toilet vent through the roof (no big problem).... The balance of the first floor (tub/sink) have a separate vent of their own....
Any upstairs plumbing will need to tie in below the connections to all of the lower fixtures.
You will need to cut concrete.
TheZster
Well, a few hours later - cutting/splicing/pounding/sweating/bleeding - and the new DWV is in - and even a layman like myself can tell it's proper.... Thanks Terry
quote; Well, a few hours later - cutting/splicing/pounding/sweating/bleeding - and the new DWV is in - and even a layman like myself can tell it's proper.... Thanks Terry
Where have I heard THAT before. I do not think I have ever heard a DIYer or handyman say, "Wow, I sure did a lousy job this time." Give us a picture of what you did and WE will tell you if you did a "proper" job.
