New acrylic airtub installation, where to put ledger?
Discussion in 'Shower & Bathtub Forum & Blog' started by chrisexv6, Nov 25, 2016.
  1. chrisexv6
    chrisexv6 Member
    Oct 6, 2008
    Installing a Bain Ultra Citt soaker/airbath. Their tech support said a ledger isnt required but I can put one if I want (and, I want!)
    Because of the molding, etc, the underside of the deck is pretty rough. Im having trouble figuring out just where to screw the ledger to the surrounding walls. The tub has a built in apron, so I cant "see" through the front of it.
    Any tips? I tried guesstimating one end and carrying a level line all the way around, but that didnt work (the guesstimated end is resting on the ledger, the other 2 sides are not)
    Thanks in advance.
    -Chris
  2. Terry
    Aug 17, 2004
    I sometimes hold the ledger under the lip of the tub where it's out in the open, and measure down to see my height that I will be setting it at.
    What does the bottom of the tub look like?
  4. chrisexv6
    chrisexv6 Member
    Oct 6, 2008
    The tub has integrated feet on the bottom. Is a ledger required at that point? I plan on using a mortar bed as well.
    I will measure the lip with the tub in the open... My only worry was that the floor isn't level so it would throw of the against the wall measurement but it should be a good starting point
  5. Terry
    Aug 17, 2004
    If the tub has feet, and it sits level in the space, you won't need the mortar. I use Mortar if the floor isn't level and I need to shim it.
    With a level floor, I sometimes just slide it in, and pin the tile lip with screws after pre-drilling. When the floor isn't level, that's when I consider shims and mortar.
  6. chrisexv6
    chrisexv6 Member
    Oct 6, 2008
    Thanks again!
    I know the floor is out of level...not a whole lot, but definitely requires that the tub be levelled some other way
    If using a mortar bed for levelling and overall feel purposes (I dont like how acrylic tubs flex), should I not even bother with a ledger? The tub deck is so small (1.5") you would be hard pressed to step on or put anything on it anyway.
    Thanks.
    -Chris
  7. hj
    The ledger is NOT to protect against stepping on the tub ledge, it is support the entire tub when someone is in it.
  8. chrisexv6
    chrisexv6 Member
    Oct 6, 2008
    With feet on the bottom of the tub I wasn't sure if the ledger was there for support. The installation manual doesn't even show installing a ledger, and tech support confirmed I can "if I want to".
    The few tubs I've installed myself never had feet on them, so the ledger was the only thing holding up the side opposite the apron.
    In my case, where the floor is out of level, should I use the ledger to bring the tub into level and the mortar bed to be the final support under the tub once its resting on the ledger?
  9. Terry
    Aug 17, 2004
    That's what I do in that case. Ledger, shims where needed on apron, and mortar. The mortar needs to be placed in piles that can squish outward. You let the tub do the job of determining the depth of the mortar.
  10. chrisexv6
    chrisexv6 Member
    Oct 6, 2008
    Thanks again, almost there! Tub is ready to be set in, will do it tomorrow morning.
    One last question - for simplicity sake, I only used a ledger on the back wall. Will that suffice? Or should I use them on the end walls as well? One of the end walls I can only get a board about half the width of the tub, because the air inlet is in the way. On the drain end, though, I should be able to get close to full length. I just wasnt sure how important the end walls are compared to the back.
    Thanks.
    -Chris
  11. Terry
    Aug 17, 2004
    I don't ledger the ends. There is all kinds of things happening on the ends, including the overflow.
  12. chrisexv6
    chrisexv6 Member
    Oct 6, 2008
    All set, the tub is in! Thanks again.
    One last question - installing the drain basket...use putty or silicone? Its an acrylic tub, manufacturer says silicone works better but Ive seen pros and cons of both. Is it just a preference thing?
    Thanks.
  13. Terry
    Aug 17, 2004
    I use stainless putty there on acrylic. I don't like Silicone for many reasons.
Similar Threads: acrylic airtub
Shower & Bathtub Forum & Blog Delta faucet, #2702 Identifying old acrylic knob with cast escutcheon? Aug 6, 2018
Shower & Bathtub Forum & Blog Small void under acrylic tub Jul 24, 2018
Shower & Bathtub Forum & Blog Bathtub Steel enameled or Acrylic Feb 13, 2018
Shower & Bathtub Forum & Blog Acrylic Corner Shower Drain Lip Jan 28, 2018
Shower & Bathtub Forum & Blog Anyone heard of this company for Acrylic bathtubs? Nov 11, 2017
