Need your input. Noble TS - drop down shower
01sesedan
Tallahassee, FL
Going to seal all seams tonight.
What could be used as capillary break? Does it have to be edging profile? Will the capillary break determine the floor tile layout.
Option A
Option B
Spacers came in.
ShowerDude
Showers
Minnesota
Joe,
For starters The pools of water im seeing in left and right corners are of concern?...when the flood test plug gets pulled ALL water should drain....residual will dry out quickly. NO POOLS
The cappilary could be an L profile, It would be "Tied into" the TS closer to the threshold and at the top of the Grade where flat floor / pan grading meet ( in your case the point where you backed up and graded the floor about 6-12" outside shower drop.
It should essentially hold water up to that point.... & put the brakes on wicking.
If you go with option A of tile layout you can still incorporate a cappilary ...
cant wait to see your progress....Now about those pools of water?? LOL
01sesedan
Tallahassee, FL
That may look like pools of water but its not. The floor was covered with layers of moving blankets. That water is from the top layer of TS that was installed on the back wall. . After it was install, I went over it with a sponge it wipe it.
Don't have a good pictures. This will give an idea.
ShowerDude
Showers
Minnesota
Oh Man !!!
You keep coming up with just the right answers!!! I have faith in you.....
Looking like a cool bathroom is on its way... I like tile choice... Crossville cross colors?
And clearly im a fan of all your material choices thusfar!!!
keep it up.... very cool...
01sesedan
Tallahassee, FL
Did a quick drawing. Not to scale but give a pretty good idea. I hope it looks close to this.
I would like to have 3 full tiles on the wall. That means I'll have a 2" gap by the floor in the shower. I don't know how a 2" strip off the floor will look. I'm trying to figure out a solution.
What do you guys think so far?
01sesedan
Tallahassee, FL
The mosaic also comes in 12x24. I'm just debating weather to fill the vanity wall to the top, full mosaic or an accent band around the bathroom.
If I go full mosaic, I'm going to order more. Original ideal was band. Bosses mind changed.
ShowerDude
Showers
Minnesota
Florida good stuffs
consider 2 things.
closer to a 30% stagger bond? unless those tiles are perfect and you use a lippage system...
drop your bottom course of room Floor tile down to accomadate the bottom course in shower.
Problem: now your niche and footrest dont line up and you have to make a hard decision!
:Note to self.... next time place niche after tile and layout!
theres still hope. play with design and multiple layouts, more accents etc...
ideally you want a nice large piece at floor, pan, and ceiling, as well as full courses at niches.....
next time
It looks like all of the boxes are from the same lot, but double check. There can be subtle texture/color changes between batches.
01sesedan
Tallahassee, FL
Was thinking of putting mosaic in the niche. Might go as far as modifying the niche so grout line match it..
I knew by starting the first row in the shower it would lower the rest of the bathroom. Not going to rush it. Too so much time to get waterproofing done. Now will spend time figuring out the layout.
I'll open up all the boxes and confirm they are flat. I've read even rectified tile may have a bow.
01sesedan
Tallahassee, FL
Just wanted to say thanks guys.
I've learned so much from JW and Red post, replies and blog's. Thanks to you guys for taking the time to educate us.
JW, I think you may be one of the few that goes beyond code. I've spent lots of time on your blog and gallery. They were very helpful.
Finding someone in my town I could trust to completely was tough. Mainly when it came to waterproofing. Some said it was not needed. Maybe I just didn't get lucky and found the right one.
He's the feedback I got.
• Just stud, plastic, durock, tile straight on concrete shower floor.
• Use Redgard or Aqua Defense. A couple coats, you're good to go. Mesh is optional.
• Noble, what is that?
• Heavy on selling the orange stuff. At a very steep price.
I figured if the install had some parts done incorrectly why pay for someone to screw it up. I might as well try it myself.
01sesedan
Tallahassee, FL
If the measurements don't change much, I'll have to keep the small strip at the bottom. Grout lines will push them up a little.
That seems like a shame. Isn't there a good alternative to avoid the little pieces at the bottom?
01sesedan
Tallahassee, FL
The thought was to put mosaic above the vanity top all the way to the ceiling. Use it was a back splash.
We have a 4" x 60" piece of granite that was cut from the same slab as the vanity top. Also have a piece for the left side. Can't take a picture of the top. That sucker if heavy.
Just didn't want to put the granite back splash on top of the mosaic or tile. Doesn't look right.
I'll be searching the web looking for ideas the next couple of days. Might draw something up.
ShowerDude
Showers
Minnesota
No ........aluminum will work.
Its more about how and where you install it.
I would try to find SS or plated brass still.
span it from wall to wall and add a bead of sealant along corners as well as under the strip .
heres a rude sketch ....of how i would do it...
01sesedan
Tallahassee, FL
Makes sense.
Gonna try to hunt down ss amd plated brass at the supply house.
I'm going to put together the floor and wall layout. Not sure how the floor tile will look again the wall. Since the wall is horizontal.
Guess I'll their should be grout line every 12 inches.
Thanks for the input.
01sesedan
Tallahassee, FL
As for the tile on the shower wall/floor corner. Instead of a 2" x 24" strip, I thought of going this route
Install the tile on the bathroom floor first, place vanity with top, and use it as a guide.
This should let me know how high I can go with the 12x24 on the wall. At the drop down, fill the space between wall and floor with 3 or 4 multi-color mosaic strips. Also put the same amount of mosaic on the floor. Then finish the floor with 2" x 2" mosaic. It'll have a carpet look.
What do you think? Will having multi-color mosaic at the bottom screw up the look?
I'll dry fit the layout and post pictures..
01sesedan
Tallahassee, FL
Working slowly on the shower. Modifying the niche to fit full size tile. The original niche did not line up correctly. This niche will be narrower and taller.
Question. I'm running out of noble 150 and would have to order more. In trying to finish this weekend. The shop in town has kerdi fix. Have you guys used kerfi fix will noble wallseal/ts? Would it seal the seams properly?
I called Noble and tech support indicated 100% silicone may/might work but I would have to test it first.
Was also thought about using mapei hpg with mesh. Its also available locally in 1 gallon size. Price difference. Kerdi fix $27. Mapei HPG $40/gal. I already have 6" mesh.
Thanks for your help....
