Need to re-route sink drain but only fittings are exposed
Jrstevens
Florida
Hello,
I have a double tub stainless steel kitchen sink that I'd like to swap out for a single tub unit. I can either get one where the drain is centered or offset to the right. The drain connections look problematic though. It is all fittings where I would need to re-route it. All the new sinks appear to be at least 2 inches deeper than the current sink, so even an offset sink would be a problem since the garbage disposal unit would have to drop down.
Please see the attached pics. Any advice on how to proceed is appreciated.
James Henry
Billings, Montana.
Pick out the sink you want, it looks like you'll have better luck with a center outlet drain, look up the specs. IE, (dimensions). cut out a cardboard silhouette of your garbage disposal and hold it up inside the cabinet where the disposal will mount to the new sink to see if it clears the drain outlet, if it don't, look for a sink where it will. You may be able to keep one of the drain outlets for a clean out.
Note that you have a tailpiece extension under the disposal drain exit, so the output dropping 2 inches or more won't be a problem.
The problems I see is
  1. that stuff is glued far from the wall, limiting options.
  2. That santee under the AAV is the wrong fitting for most codes, but will work fine.
If you needed to replace that santee, then you would use a Pipe Parana tool to remove the santee, letting you glue on a new combo to hold the AAV and mount the new trap adapter. I have not used that tool, and I don't know how easy it would be to use without experience.
James Henry's suggestion was the best and easiest. At first I missed that the elbow farthest from the wall was in a trap adapter, and not glued.
Jrstevens
Florida
Thank you both for the advice!
The Pipe Parana tool looks interesting. I also noticed the "Pipe Hog" tool while researching the Pipe Parana. If I go this route, I'll glue-up some test fittings just to try out and get used to the tool first.
One additional question - would an internal PVC coupling work where the yellow arrows are drawn in the attached pic? Or would an internal coupling be non-compliant or otherwise a bad idea?
Take a look at RamBit and Socket Saver also. That would be the more approved alternative to an inside coupling.
