Need to identify faucet stem manufacturer
Reno Weary
Atlanta, GA
The cold-water right faucet handle on my bath sink has become stiff to turn. Neither the stem mechanism nor the handle or faucet have any i.d. on them. I would like to replace the stem mechanism to repair the problem. Would you try to identify at least the manufacturer? I read that Savoy, Wolverine, and Sanco have 15 spine stems but it seems I could look at photos online forever and not find it.
Length of the part with the splines is 3/4 inch. This part is divided by a shallow crevice around the circumference so the very end section is 3/8 inch and the lower section is a little less than 3/8 in. The diameter of this part is 5/16 in
The length of the entire mechanism which is one piece is 7 in, the widest part of which is 1 3/8 in.
This has a white porcelain-looking handle and has a white cone-shaped 1.5 to 2 inch porcelain decorative piece below the handle. See photo
Can you identify? Or narrow it down? Thank you!
Asktom
Victor, MT
Your picture shows the faucet body with the cartridge (stem) screwed into it. Remove the cartridge and post a picture of it next to a ruler. Does the broach have 15 splines? 16 is more common.
