I was hoping someone could offer me some advice. I have a propane wall mounted heating unit. It has a one gallon(or so) water expansion tank built into the unit. I also have a 2 gallon water expansion tank installed and attached to my indirect hot water tank. The other day I was bleeding my baseboard heating pipes and I think I let the pressure in the pipes get too high causing a slow drip from the water expansion tank in my wall mounted heating unit. My questions are: 1) Do I need to replace the tank in my wall mounted heating unit or will the water expansion tank attached to my indirect hot water tank be sufficient? Can I just cap off the pipe to stop the leak? 2) If I need to replace the water expansion tank do I need to replace with the exact same one? They no longer make my "Fais" brand units? Can I replace it with a 2 gallon talk using flexible copper piping and house the replacement tank outside of the unit? 3)Can I fix this myself or should I call a plumber. I feel I am pretty handy.
The unit was built in 1990 by F.A.I.S. in France. Model # AR-820
Any advice is appreciated. Thanks, Jeff from VT.
http://pic60.picturetrail.com/VOL1683/10152743/18258584/287330865.jpg
http://pic60.picturetrail.com/VOL1683/10152743/18258584/287330850.jpg
http://pic60.picturetrail.com/VOL1683/10152743/18258584/287330845.jpg
http://pic60.picturetrail.com/VOL1683/10152743/18258584/287330840.jpg
http://pic60.picturetrail.com/VOL1683/10152743/18258584/287330835.jpg
