AcE101
Thank you in advance for helping.
I just finished the installation of my water softener (2.5 cft with Fleck 5810 XTR 2 valve) and catalytic carbon filter (2.5 cft with Fleck 5810 SXT valve) systems last Sunday. All went well and we had soft water on Sunday night, but last night i noticed that my drain line has continuously flowing/dripping water. So i turn on the bypass valves for both systems and trying to figure out which system was leaking. it turned out that the carbon tank was continuously forcing water through the drain line and it only happen when there's no usage of water in the house. If i open the near by water hose, it stop leaking. So i was thinking may be the valve didn't shut down completely and when the water pressure inside the tank reaches certain psi, it will cause leakage through the drain line. (my main water line pressure is only 50-65 psi and i'm in the City) This didn't happen on Sunday night after the system was set up, regenerated and run. Is there any quick fix for this? Thank you!
edited to remove dealer info.
