Need Help Programming Softener/Filter and Setup?
TxHr
Texas
Sorry for the confusion, I fat fingered my hardness. In at 30 GPG, not 40. Either way, I’m gonna be using a lot of salt
Multiply 3o by 1.2 for the compensation for high hardness, so H=36.
That would give a 3.33 day estimate, which might be 4 if you use a little less water.
TxHr
Texas
So I just need to adjust those two factors in my programming and I’m off to the races??
TxHr
Texas
Also, do you recommend trying 6 lbs salt instead of 8 initially with these new settings?
Never mind, I just read your previous post and answered this question.
Only H. The days estimate is not programmed in.
For H, you don't need to go to the Master Programming Mode. You get to the User Programming Mode as you would the master, but you don't set the time to 12:01 pm.
I see I was computing for 5 people, which is not yet there. With shorter forecast time between regens, it may be that the higher setting gets another day out of it. You could observe your usage to see which works better. At 6 lb/cuft the forecast is 2.78 days, and with 8 lb/cuft it is 3.33 days. So if your usage happened to be 300 gallons per day, that would be the difference between 2 days and 3 days.
If I compute for 4 people, using 240 gallons per day, the respective numbers are 3.47 and 4.17 (which would mean 3 or 4 days).
If you are expecting guests the next day, you might trigger a regen to happen earlier than it would have.
TxHr
Texas
Awesome. Thanks again for all of your help. I appreciate everything.
TxHr
Texas
My softener has performed two successful regens since making the programming adjustments. Last night, there was a regen and my water in the house is now back to having the taste as there is no salt in the tank. The brine tank is full of salt and it was cleaned last month. Where should I look to fix this issue?
Thanks,
Brandon
What taste is that? Iron?
What does that mean?
How many inches of brine/water are in the brine tank between regenerations? When you do a regeneration, how far down does the brine level fall (measure that maybe 40 minutes after the regeneration cycle starts).
