Hi
I have been coming to this website for years and gaining all kinds of information. Until now I have not had a need to post. I am faced with an odd situation for which I need the advise of the pros here as well as the comments from the rest of ya ;-)
I am doing a bathroom remodel and I have a busted toilet flange. It is cracked at one of the bolt slots.
I have never seen a bathroom floor like this. It is made up of 2 layers of 3/4” plywood. There is a whole large enough in the top layer of the ply for the flange to come through. The flange looks to have 'feet' on it that make it about 1.25” thick. (pic 2)
The flanged is screwed from the top down into the second layer of plywood.
In this pic you can see the floor that I am removing.
The floor under that was self stick vinyl tiles. I believe that when this vinyl was the finished floor that the toilet sat about 1/2” or more above the floor. When I pulled the toilet the flange was below the floor by about 1/8” because of the thick flooring.
I put the flooring that I will be using on top of the vinyl tile and it looks like I have about 1/4” of flange above the floor.
My plan is to use a Sioux Chief metal repair ring on top of the cracked flange. This will give me a bit more height.
I also plan on using appropriate fasteners and replacing the shut off valve.
I am using a PVC plank flooring so I will get that to about 1/4” diameter around the flange and then caulk the gap between the edge of the flooring and the flange.
I was going to use a standard wax ring but wanted to run this install by the folks here first. I am open to other options if need be.
Please let me know if my proposed plan sounds good.
Thanks !
Thanks !
