NEC 2017 dishwasher question
Gagecalman
Active Member
Baltimore, MD
Hi all,
I live in Baltimore City. I have a question about the requirements for wiring up a dishwasher to the NEC 2017.
I know there are some changes. I would also suspect they would apply to the garbage disposal as well.
This is what I understand.
The dishwasher receptacle must be installed in the space adjacent to the dishwasher, and not in the space the dishwasher occupies.
The two receptacles (for DW and GD on separate circuits) must be AFCI protected.
They must be GFCI protected if within 6-feet of the “top inside edge of the sink bowl”.
So if they are mounted in the sink base cabinet put them on a AFCI/GFCI breaker.
Thanks in advance for the help.
You did not specify the question. If you are asking if you need an AFCI+GFCI breaker, you could use AFCI+GFCI outlets instead.
Gagecalman
Active Member
Baltimore, MD
I guess I forgot to ask the question. Too much typing.
Per the requirements of NEC 2017 do I have to have AFCI and GFCI protection for the two receptacles in the sink base (one for DW and one for GD on separate circuits)?
Thanks for the reply.
Stuff
Pennsylvania
DW yes for both. AFCI yes for both. For GD it depends on how your local authority defines "door" since passing through a door is exempt from GFCI. Is a cabinet door a door?
Gagecalman
Active Member
Baltimore, MD
I will call the office today to hear what they say.
I did a search and there's a lot of different opinions about "is a cabinet door a door"?
Some say code is a minimum and if you are required to AFCI protect you might as well put it on a AFCI/GFCI breaker.
I wonder if they handle a microwave receptacle the same way if it's next to the sink.
Norcal01
A dishwasher requires GFCI protection NEC art 210.8(D) new in the 2014 NEC, they also have to be accessible.
