Navien 210-A2, Best way to get 12 inch horizontal separation?
RCY
Burlington, ON
Hi, everyone. I had a Navien 210-A2 installed a couple days ago. First, the installer had the intake on the tall vent and the exhaust on the small lower vent. I asked Navien and they said exhaust should be higher. They also said 12 inch height separation is good but there should be 12 inch horizontal as well. They also said no need for the vent mesh caps.
This picture is from before I moved the taller vent pipe to the left and the smaller to the right (to get low intake and high exhaust), so imagine tall on left and short on right.
To get the 12 inch horizontal separation that Navien suggested, is it better to extend the exhaust more to the left or extend the intake more to the right (remember it's reversed from the picture now)? Also, do you agree about the vent caps?
Thanks in advance.
P.S. it was done this way because I had a Rinnai R75 LSi (from 2009) that had a concentric vent and asked the installer if he could avoid any more holes in the brick, so he used the hole from the old concentric vent.
John Gayewski
Iowa
I would turn those 90's on 45 degree angles and put a small travel peice on each one then 45 back to plumb. That is if I cared that much. If it were me I'd do it right the first time or leave it.
The manual shows that you can install venting with this kit by Versatech.
Page 54 of the instruction manual.
It's side by side for both intake and exhaust. It's a little confusing isn't it.
Page 17 showing intake air from inside. Which you can do in certain circumstances. I see that often when installed in a garage.
RCY
Burlington, ON
Thanks. For simplicoty, could I just extend the intake sort of like this..
RCY
Burlington, ON
Thanks. That Versatech kit is.definitely not 12 inches exhaust to intake, so I'm not sure why the two pipe I have needs the 12 inch horizontal separation
RCY
Burlington, ON
Ended up doing this. Any reason this isn't good? Could have been a bit shorter, maybe?
Vertical pipe is exhaust. Horizontal is intake.
bingow
Active Member
New Mexico, USA
Around here, bluebirds (and probably several other breeds) would absolutely fly into that vertical pipe, and cannot get back out. It should have a grid cover.
I would consider applying latex paint or Plasti Dip spray paint or Desert Brown camo tape.
  • Like
Reactions: RCY
