Scott Graham
Well is 300’ behind my house, Well depth is 140', Pump depth is 120', pump is a 1/2 HP Gould submersible. I have two 42 Gallon Pressure tanks. Pressure switch is set at 20/40.
About seven years ago our well trouble started. My wife was in the shower when the water stopped. Being a 1st time well owner all I knew to do was call a well guy. He comes out goes under the house and diagnoses a bad pressure switch. Replaces it come out from under the house and states the pumps not holding pressure. Out to the well he goes and replaces the ½ HP Gould with a ¾ HP Gould pump. We run the well for a few minutes at the garden house after about 5 minutes it cuts out again. At this point his diagnosis is that my well’s going dry. Gives me a $1500 bill for his 3 hours on site, New Pump, etc. and leaves.
Next up, I call a different well company out. They pumped the well down, let it rest 30 minutes and we pumped again. We got around 50 Gallons in 8 minutes (IIRC they calculated well recovery rate at 1.6GPM). Then the water stopped again. They only had a 3GPM dole valve so that’s what they installed. They recommended Acidizing the well. So we tried that and no improvement was seen. They also felt the ¾hp Pump was too large and tested my ½ hp pump and reinstalled it. Of course one of their other options was to drill a new well. So out came the drilling rig, they went two dry holes, packed up and left.
At this point we were financially drained. And have to live with a well that went out 6-7 times a day. We looked at water usage cycles trying to determine just how much we could use at a time without the well stopping and never found a consistent pattern. We tried but had no luck with turning the pump off (without the water out) for 30 minutes prior to bed, but we would typically awake to a water outage.
The only constants we found were.
1. When the water went out it stayed out (even for days), until we turned the pump of at the breaker and let it set at least 15 minutes.
2. Before / during rain’s it would act up more.
We lived like this for two years. Then all of a sudden, all of our well issues went away. At this point I was scared to use too much water, but after a few years of the well acting fine I started to lose my nervousness every time I turned a tap on. We could Shower, Do laundry and run the dishwasher all at the same time and the well kept up. That was until last Friday. I got home from work and while the water wasn’t out it was a very slow trickle. I turned the pump off, waited a few minutes and turned it on. I heard the water in the pipes. Saturday water usages was normal, until I was in the shower (laundry running), I noticed pressure was slowing down. So I got out of the shower, turned the pump off and waited 30 minutes. Turned it on and heard the water come in. I didn’t know it at the time but a few minutes after I turned the water on my daughter took a very long and luxurious shower (according to my son 40 minutes at least). No water outage. Sunday we had no water outages. But needless to say I’m scared. Last night our new washing machine (less than a month old) has a “No Fill†situation on cold cycle. It would fill hot/warm. I checked the fill hose filter and it was plugged with iron flakes. Of interest Since Friday afternoon it’s been raining VERY VERY hard.
Sorry for the long read, but I hope it is helpful. So any incite anyone has that may help solve my Well Riddles is appreciated.
1. Why do we have to turn the pump of (for at least 15 minutes)?
2. Why does the well’s recovery rate fluctuate so much?
3. Why does rain make the well act worse?
