My Ensuite Renovation WIP
Got three pieces of horizontal trim up & a corner trim piece. Friend started feeling sick from the smell of the adhesive (I didn't even notice a smell from it at all but my allergies have my nose plugged up a bit).
Because of how I shimmed on the side wall (due to how it tilts) I didn't have to cut the corner trim's edge out of the way. I also didn't have to notch the vertical trim. I took a scrap from the part cut off the top and am going to rip it to 1/2" to fill in the gap under the L-bead on the right side. I may have to shim behind, but I will see how it fits without first. The side pieces are cut to size. The come up a little short because I wanted a slight expansion gap between the boards and the floor just in case.
Since my friend started feeling sick after the corner trim, back wall trim, and right wall trim were up, he messed up cuts for left wall. Ended up with a 1/8" gap. But he had a 1/8" too long that he had to cut off on another board so I can use that piece to fill the gap.
The corner trim covers the ugly edges of the printed plywood panels nicely.
Gap on the left side trim
After my friend took a break and got some air outside, he came back in & hooked up some of the plumbing. Cleared the lines before connecting them to the valve. The flange for the control's trims is loosely on. We have to wait 48hrs for construction adhesive to cure before trying to drill through the trim for the showerhead. Once the showerhead is in place we can secure everything, drill the holes for the screws/bolts on the shower controls, and caulk around stuff.
There have been some hangups and delays but I've made a lot of progress.
Things done since last post:
*Cut a piece to fill in gap between the top trim and side trim a bit better
*Vacuumed & cleaned up a bit (but stuff got dirty/messy again)
*Patched damage to sheet vinyl where mouse chewed
*Used scrap pieces of tear away strip from L-bead trim to cover some gaps between top of surround and trim
*Frankensteined pieces of the pvc trim together to cover more of the gap between side trim and tub
*Caulked & painted the Frankensteined side trim
*Nailed up side trim
*Nailed up 3/4" quarter round next to left side trim to cover gap (it had to be shimmed to be flush with surround & other trim)
*Nailed up flat trim (don't remember measurements) to cover gap between right side trim & corner trim
*Nailed top trim over the other trim to cover gaps so nothing can fall down between trim and wall
*Got plumbing all hooked up (which was a bear because of things not being straight)
*Shower arm, flange, & showerhead installed
*Shower controls and trim installed
*Tub spout installed
*Baseboard in front of tub nailed up
*Rear shower curtain rod up (to hold hooks for loofahs, back scrubbers, etc)
*Nailed up cove moulding to inside corners
*Glued up flexible trim to cover gaps between surround &
I need to caulk, touch-up paint, clean up, and put main curtain rod & shower curtain up in order to use the shower. Well, touch-up paint can wait. Spent 5 hours working on it yesterday & my feet were swollen & back was spasming. My friend did most of the work but I helped hold things in place, handed tools, helped align things, etc.
The escutcheon for the shower trim doesn't want to sit flush against the wall for some reason so I will have to caulk. It's not much of a gap, but enough that I want to caulk around it.
Every time I try to post a picture I get "Oops We ran into some problems" message. I'll see if I can post later.
I'm going to see if the pictures work now.
Ok, apparently not. I'm unable to upload or even paste images in. Anyone have any idea why? When I tried to upload there were no images. Just blank. Not sure what I'm doing wrong. In the past I could just paste images in and they would attach but I keep getting an error every time.
Going to try to link from a tumblr page to see if that works.
Ok. I give up. I don't know why nothing is working.
It is not something that you are doing. There is a problem with the site. Your tumbler pages did not work, as you may or may not be able to see. You may need to log in to see the photos. If you see the photos, it is because you were logged into that site. Be patient.
I saw a thread about the image problem. Really not sure what the issue is. I'm logged in to tumblr but can't see the images. I hope whatever is wrong gets fixed soon. I want to share the photos.
Stomach hates me today bc of something I ate yesterday that had me sick all day. I shouldn't have eaten that stew with onions. I know they are bad for me and make me sick but the stew was so good. LOL. I have a love hate relationship with onions. Love the taste, hate what they do to my guts.
If they fix the issue with the images I will try to post pics later.
You might try this Google search:
google make pictures public
Here are similar search terms to try for Tumblr pictures:
tumblr make pictures public url
I don't have experience on that myself.
They should be public. They've always worked in the past. I'll mess with it later. Right now I'm resting my back. I finished caulking today. Just waiting for it to cure.
Pics are still not working but caulking, priming, & painting are done. I just took down the tape and plastic and am letting the paint dry.
Still another 48hrs before the caulk fully cures I think. The paint seems to dry somewhat quickly, but I'll give it 24hrs I think. They no longer make that paint and the paint spilled on the instructions on the container. Got it back in 2008 but its still good.
Looks like Tumblr pics worked now. But I'm going to try to post some here and see how it goes. Finished caulking & painting, got shower curtain rods up, curtain up, hooks on back wall rod for backscrubbers/body scrubbers, got a suction cup bin to hold bath gloves & hide the patch job over where the tub was gouged. Got tp holder and towel bar up.
Still need to clean up more and get the robe hook up. Tring to determine what height to put it at. What I plan to hang on it is not very long. I have a board with pegs for taller stuff right near the door. I want something closer to the shower to put on a wrap right after getting out.
Prepped for painting by taping and putting up super thin plastic.
More pictures in next post.
Pictures (continued).
After removing tape-- its very sloppy and nowhere near perfect but I'm satisfied with it. I do need to fill in the holes from the old towel bar but that is not urgent.
more pictures in next post (not sure how many can fit in one post).
More pictures. Last pic was of the toilet paper holder (I cleaned up the floor after that-- the messed up wall painted white will be covered with wainscoting). Towel bar. Please excuse the distortion. It got all weird because I had to resize smaller so the image could be posted.
I added the clear plastic bin thingy for the gloves to hide the sloppy repair job on the side of the tub. The anti-slip mat inside is soft/cushiony and can be stuck to the wall to dry after a shower.
I got a foot scrubber to make it easier and safer to clean feet. It has suction cups to hold it in place and can be put on the wall to dry.
Back scrubbers (the blue ones are mine-- gray are for my brother once he brings his shampoo, bodywash, etc in). He has more products than I do.
Next steps:
Hang robe hook
Clean up bathroom- get rid of junk, put away tools, etc
Sand and paint vanity (after caulking to get rid of some gaps)
Put new hinges on vanity doors
Install vanity door and drawer hardware
Sand & paint dresser
Install new knobs on dresser
Install wainscoting, baseboard, chair rail, & corner trim
Sand & paint ceiling trim
Sand & paint window trim
Replace faucet
Replace vanity trim (ugly wood) with vinyl cove moulding
Make & install new mirror
Replace drain
Install vanity light and add new switch
Replace switches for vent-a-light heater in ceiling
Install light over shower (shower rated)
Cut open wall behind toilet & fix DWV
Cut access panel under tub from closet side to replace drain & overflow
Sister up and make box for cut joist under tub
Either move board with pegs so door no longer hits it or trim pegs that hit the door shorter
Sand & paint door & its trim (possibly replace trim)
Put mirror on door
Replace knob on door
Install holder for mop & broom
Add shelving or cabinets on wall above laundry cart
Install johnny cabinet (aka tank topper cabinet) above toilet
Install shelf above tp holder to hold wet wipes
Knocked one more thing off the list:
Mounted the robe hook. It was a pain because the screws stripped out (I pre-drilled but they were designed to go into drywall anchors and I was trying to put them into a stud). They got stuck almost all the way in and removing them was a pain. I accidentally scraped the wall trying to get them out.
I had to put the opening of my cordless drill around the heads and draw them out. I used star head deck screws instead and that worked out much better. Used a small magnetic level to make sure the bracket was straight (although the walls are not straight so it looked a bit crooked).
Used a precision screwdriver for the set screw. Also tightened the set screws on the tp holder bc they weren't as tight as I liked and I only recently found the screwdriver set.
Still need to hang the towel hook (I don't want it in the same place as the old one) and try to hide the damage to the wall. Eventually I want to add shelves and cabinets.
Obviously I still need to clean up and get rid of the clutter.
Your journey with bathroom renovations sounds like quite the challenge! From dealing with old carpets and damaged subfloors to struggling with leveling compounds, you've put in a lot of effort to improve the space. Despite the hurdles, your progress is commendable, and sharing pictures can inspire others facing similar challenges. Keep up the good work!
Thanks. I haven't posted in awhile. Whole family got Covid and my mother almost died-- not from Covid, but from a kidney stone that triggered diabetic ketoacidosis and put her in ICU for awhile. I will have to dig up the photo, but I added a suction cup towel bar for my washcloth. It keeps falling off so I may need to resort to using the sticky tape things it is supposed to stick to, but its very easy to put back on.
Haven't gotten rid of the clutter yet. Been busy will all sorts of other things and my back doesn't like me.
Here's the suction cup towel bar. It keeps falling off so I may have to use the included adhesive disks, but its very easy to put back on so it hasn't bothered me too much.
30502-d7f27f299ccd0539e160aa92c105d929.data
Today I put up a new shelf. Cheap one from clearance at Walmart. It's not quite level but I will move it and level it when I do the wainscoting and chair rail moulding.
30501-71c487a97fcbc7799bc16321be179e83.data
Now I need to find a place to mount my shattaf. I decided to go with that instead of a bidet seat attachment. I don't want to hang it off of a hook on the toilet tank. It looks something like this:
Not sure why some of the pictures aren't working. Some more info on updates and what I plan to do in the future. I plan to put in Pfister Sonterra with popup drain.
I'll install a Danco hidden screw overflow plate in the tub when we re-do the drain to not go through a .
I also plan to put in a paper towel holder on the underside of a wall cabinet.
I'm either going to build or buy a cabinet to go over the toilet (it will NOT have parts that touch the floor and it will be high enough that it will not get in the way of maintenance on the toilet fill valve and such).
I also plan to build a cabinet above the laundry cart to store paper towels, toilet paper, wet wipes, disinfectant wipes, cleaning supplies, etc.
I made a very rough sketch of that. Measurements may change after I measure some of the stuff I want to put in it.
Both wall cabinets will be mounted to french cleats that will be secured to studs. I may use angle brackets for support in the middle of the larger cabinet. I want to use some oak trim for face frames. As much as I'd like to have raised panel cathedral style doors, or even flat panel ones, I'll probably just go with flat doors because they are easier to make.
Another door came off the vanity cabinet and the hinge broke because I'm a klutz. The white hinges looked terrible so I got chrome instead. I'll have to fill in the holes with toothpicks to give the screws something to grab and possibly use slightly longer screws or just stronger screws so the doors don't just fall off. Need to putty the gaps/voids in the plywood on the doors, sand, paint, and put the hardware on.
I also need to remove the current mirror and cut a hole to be able to run wires, pull the outlet out of the way, cut a larger hole to add a switch for the vanity light, and tap in to the power from the outlet to run the lights (will be LED bulbs so low voltage draw). Trying to figure out the best way to be able to drill from the existing outlet to around the corner without having to cut out too much of the wall panel as I want to preserve it. Won't matter if there's a hole behind the mirror since it won't be visible. Speaking of which, I need to add a frame to the beveled mirror I got.
I know that's all a lot of planning, but I did actually make some progress. As much as I liked the wood tone of the door, it was stained and that would not come out. (old pic of the door when I was taking pics of the flooring install progress).
1st coat of primer looked horrible. I did sand it first but I applied with a crappy brush. Looked like I had rubbed chalk all over it.
I sanded again and did a 2nd coat with a roller and it looks a little bit better.
I will be replacing the knob with a lever that is chrome on the inside of the bathroom. I will paint it blue once my water well is working properly again and its not too hot. Then I'll put on a 13"x49" door mirror. It is lightweight.
The trim for the sides of the door goes all the way to the ceiling. I'll fill in knots, sand, and paint that white. The rough wood texture gives me splinters. I also want to add a small shelf above the door.
