View attachment 59917 View attachment 59918 Ibought a Morton M30 softener and it was installed it about a month ago. I know it was working fine in the beginning but lately it seems that water isn’t soft.I believe it confirms it when using the control board it says it has only regenerated 3 times. (and we have a 5 person household). When (using control board) I go to the water meter to see if water is going through system, the panel (according to manual) is supposed to look like this ( 000- - ) or ( 000-P ) the “P” stands for position, if the P is there then the position of the switch is closed, if the dash is there then switch is open. What switch they’re referring to I’m embarrassed to say I’m not sure. Of course when I go there the panel reads (000H- ). The zeros are supposed to count gallons when you run soft water through the system.
( 001- -) (002- -) etc. when I currently run water from a faucet the meter never increases. I believe that whatever the “H” stands for is the reason I’m not getting soft water. Of course the softener manufacturer Morton tells me nothing in the manual or on the website about any code beyond the “P”. Is it too much to ask of them after I buy their product for them to give me all available codes? Of course I would phone them if it wasn’t a weekend. I guess they figured the water can wait until a weekday.
Does anyone have an idea what the “H” means? Or what I should try to do to get this working? Thanks for your help.
