Lower Kitchen Drain
Danno M
Naples, FL
Hello everyone! Thanks in advance for any assistance you can provide.
It's a story as old as time. Added a deep sink during kitchen remodel. Now the garbage disposal outlet is slightly below existing drain.
Attached is a picture of the current drain situation (disregard the sink basket drain in the picture, that will be replaced with a garbage disposal). Is there any way I can lower the drain so I can fit a p-trap between the garbage disposal outlet and the drain without having to cut into the wall? I think I only need to lower it a few inches to make it all work.
Thanks again!
Replace the 90 bend with a santee and come straight out of the wall for the p-trap.
The AAV can still come upward the 4" or more that is needed.
Danno M
Naples, FL
My first thought was to cut the 90 at the wall, get rid of the flange, and then attach a wye on the remaining stub of pipe coming out of the wall. Reattach the air vent to the top of the wye and then put a p-trap between the remaining branch of the wye and the garbage disposal outlet. Too easy?
If I have to cut into the wall, I think I will need to summon professional help at that point.
Danno M
Naples, FL
That was my first thought too, great minds think alike! But I read somewhere that you can't put a sanitary tee on its back??
For an AAV nobody is going to care. I see it all the time for that.
the santee on back for that I don't think is an issue on IPC code anyway kind of a minor thing exposed like that UPC as well a wye might be better or combi but not much of an issue.
I think danno can cut that off right at the hub discard the escutcheon and perhaps put a split flange with a little trimming with tin snips or many houses don't use escutions on waste line stubouts anyway
Danno M
Naples, FL
Much appreciated!
Danno M
Naples, FL
Awesome thanks!!
Here's the finished product. Thanks again!
